Really weird light problem :-((
I hope this is a 'duh' fix, but here it is:
Top left tail light on truck stays on when engine off and key removed. When truck is on all four tail lights, head lights and front turn lights stay on -- no changes when blinkers on or hazards on, no change with brakes being applied except that third light on cab lights -- also reverse lights work. Ideas?!
DTR's 'Go to Guy'
THAT sure sounds like a TIPM issue. Now.....what caused the TIPM to freak out will take a little to determine. Check for body codes if it happens again. To do that, hold the trip reset button while turning the key on. The guages will freak out and do a little dance, then any body codes will show in the odometer screen. You can compare the body codes to this chart.
rbrettctd
10-27-2008 01:38 PM
Common
04-09-2008 10:25 PM
z1bigtom
07-30-2005 06:04 AM
