Real world towing with WATER/METH?????
towing with things turned down or off is no big deal at all without water/meth... twins do a very good job cooling things down, however, if I want to put a little more power to my climbs or onramp acceleration or whatever the water/meth will allow for higher smarty/tst settings while still keeping towing egts in check... for me while towing in check is below 1200* water/meth gets me there no problem...
ps my average load is right around 15k but ranges from 4k to 30k
One of my big questions (soon to be answered) is: For those guys out there with new trucks NOT looking to purchase programmers or bigger turbo's/twins "which is the bigger bang for the buck for towing?" Keeping in mind that most people are towing 10K lbs. - 20K lbs with a GCVW of 16 -25K lbs.
Lets face it, most people purchasing a new diesel truck are using them for towing TT or 5rs, some with campers and car trailers, most of which meet the range of 16-25K lbs GCVW. Those that are dragging and sled pulling have completely different goals and needs.
I plan on loading my truck down when I first get the water/meth and running the truck in stock mode, levels 1,2,3 on the Edge programmer to test. I am curious to know? Did I really need to spend the money on a programmer? Will the water/meth have done the trick by itself? Keep in mind my goal: 1) To be able to run 6%-8% grades with 19K lbs GCVW at 65-70mph and not exceed 1250 EGT's. 2) To balance enough HP/Torque to do the job and not eat an auto transmission.
I would definately say that for the majority of us out there doing everyday towing, the purchase of cold air intake and opening the exhaust is a must. Everything else is relavent to the goals of the driver.
rodriguez7
12-02-2009 11:08 AM
jdpiii
06-19-2008 07:34 AM
Dusty Ratcliff
01-30-2006 09:23 PM
