Real time data
Real time data
Drove into work this afternoon with the Diablo as a diagnostic tool just messing around.
Picked out the HPCRpressure mode and watched as I drove.
In park at idle, I was seeing 46.00Mpa-48.00Mpa which I believe is 4600-4800psi.
In gear at idle, pressure was bouncing around between 5300-5700psi.
I wasn't able to go full throttle at all, nor build more than 10lbs of boost due to traffic conditions.
I did see the highest pressure in the 14,000psi range but most cruising speeds of 35-45mph and it was reading between 9500-12000psi.
I'm going to keep a log to see what highest pressures I see, what average cruise pressures at certain mph's, etc..
Then, when I re-install Quads XZT (after they change the tune), I'm going to see if it'll read any changes.
There is alot of cool stuff to monitor with this programmer.
Pressure correction Calculation
you are a little off on the pressure there. here is the calculation.
1 PSI= 6.895 KPA =.006895 MPA
10 PSI= 68.95 KPA = .06895 MPA
100 PSI= 689.50 KPA =.6895 MPA
1000 PSI= 6895.0 KPA =6.895 MPA
10000 PSI= 68950.0 KPA =68.95 MPA
and so on.
1000 KPA = 1 MPA
46.0 MPA = 46000 KPA = 6671.50 PSI
My job is dealing with pressure so i just thought i would point that out for you.
Also, i think that the 14,000 PSI is a little high. The injector line is only rated for 10,000 PSI if i remember correctly.
and so on.
1000 KPA = 1 MPA
My math is a little rusty. Could you give me a formula to convert Mpa to psi.
Also, I read many times, that pressures do exceed 23,000psi at the injector.
What I was reading was in Mpa. And the numbers were 46.55 - 142.99, etc...
Originally Posted by trik396
I now know that Mpa is not times 100 for psi calculations.
Looks like pressures at 142.xx Mpa are over 20,000psi
yep, thanks for the info, i learn something new every day.
well, to get it from Mpa to Psi, here is the formula.
142.99 mpa x 1000 = 142,990 Kpa
then you take 142,990 kpa and Divide it by 6.895= 20,738.22 PSI
Redsmoke
23
11-19-2009 10:50 AM
kingoffools
06-07-2009 11:48 AM
