RAQ stereo Aux input options?
You could install a wired FM modulator.
http://www.crutchfield.com/S-1OWUtdX...g=251550&avf=N
Can also find them at Circuit City and Best Buy.
MikeyB
MikeyB
Thanks for the tip/link MickeyB. Reading the specs & reviews, that looks like one of the better FM modulators out there. I am going to have to go only for direct connection though. Even good FM quality isn't ideal and many of the reviews point to noise and interference. Ditto on the noise level for cassette adapters. My personal experience with other FM modulators has been abysmal... could be all the radio towers around here &, when traveling I hate getting bumped when a station comes along at the same frequency.
I see that Mopar's IPod Integration kit also has a 3.5mm stereo input (F).
So that may be a good direct connection solution for some. I don't have an IPod, so it's overkill for me.
The leading contender I've found thus far is the AAI-CHY from PAC ~>
Auxiliary Audio Input for Chrysler, Dodge and Jeep vehicles with Satellite or VES option.
• Two Auxiliary Audio inputs.
• Accessory +12 volt wire output.
• Left and right signal adjustments for each input.
• Plug and play.
• Works with Navigation (REC), 6 Disc/MP3 (RAQ), 6 Disc/Cassette (RAK) and Single Disc (REF) model radios. This is indicated on the front of the radios by the right ****.
• Plug and play.
I would go with the PAC. USA-Spec may make one for our trucks also. Whatever you get, let me know because I have the same head unit and the same issue, but I want one input for my Sirius and another for a DVD player.
MikeyB
Try out PIE.NET
Click on the products tab, they have adapters that provide direct connection for a bunch of stock stereos that will let you plug in accessories. My BIL uses one in his Honda and loves it. It sounds better than a wireless FM modulator.
~Rob
~Rob
You may have misread on how the wired FM modulator works. Granted, it's FM quality signal but there is no noise or static. When the wired device (sat receiver, ipod, etc) drives the signal the modulator box turns off the external antenna so no FM radio signals can be picked up. I have one for my Sirius receiver, and tell you the truth, I can't tell the difference with audio quality between the satellite receiver and playing a CD.
MikeyB
MikeyB
Thank for the link hotdram. I'd suspect that direct connect would always be of better quality than FM modulation... although with really good FM mod, direct, with no noise it may be difficult to audibly differentiate the two. Still, FM Mod seems an unnecessary step if one can just go direct. I'm surprised Dodge didn't just have an Aux-In (or 2) on their top end stereo.
Checking the PIE website, their application guide lists compatibility with 2006 RAQ units (probably GTG for '07's as well) ~> part# CHRY04-AUX/S
Not an awful lot (any?) of tech detail on their website. I found a bit more on this EBay Listing. Looks like a single RCA output/connect. That'd work.
ptgarcia ~> I think that PAC product is still the best candidate. It is direct, variable gain for two (2) Aux Inputs and works as selection VES on the mode select. I think I'd wire it up so that the 2 RCAs convert and terminate to 3.5mm stereo F inputs; one on the dash and the other in the glove-box.
Thanks again for all the input (no pun intended, lol).
wreedCTD
04-09-2007 07:06 AM
Jus Cruisin
15
02-15-2007 08:45 PM
