Raptor Questions
Raptor Questions
Well I can get a fuel filter, W/F seperator very cheap, so I was thinking about running the 150 raptor. I was reading through some old post and am confused whether you have to run a draw staw through the tank or not? What Id like to run is, run the Universal raptor (http://www.glacierdieselpower.com/pr...pf_id=RP-150-U) inline with the stock piping w/ out the drawstraw and run it into the w/f seperator. Would this work or am I wishing to high?
it would probably work but, the stock tubing is only 3/8" and that's at the tube off the tank too. You're really defeating the purpose of the bigger pump which is to move more fuel. It's like recommended to run the 1/2" lines that come with the kit and by doing that, you'll need to deal with the tube.
It's really easy to install a new tube in the tank. I did it by myself. It helped my truck is a couple feet off the ground though and the tank was almost completely empty.
I use the stock piping for a short distance...and it works...ok. I will probablt have to fix it at some point. It is my choke point now. The OEM tube is actually 5/16"...not even 3/8"...lol. But it is working for now up to 800hp or so demand of fuel to twin cp3's.
Names_TJ
01-19-2009 08:54 PM
megaboom
13
01-16-2009 11:52 PM
84mphcdt
16
12-19-2007 11:31 AM
rangerst
13
01-26-2004 12:59 PM
