Raptor 100 install...need to remove stock pump??
I have searched and read conflicting info. If I install a Raptor 100, won't I be able to pull fuel thru the stock set-up if I just unplug it (since it is a flow thru design)? I have read that I can and also that I need to remove the stock one. I would love to be able to leave the stock one since it still works as a back-up and just plug it back in if necessary.
Administrator/Jarhead
You cannot run the raptor through the stock pump if you unplug it, nor would I suggest it (lessons learned). You can leave it in there, but you'd have to do some custom plumbing.
That's fine, just wanted to make sure. It does use the factory pickup though? I don't need a drawstraw or anything? I don't want any "1/4 tank" issues that I have read about.
Backwoods Bumpers
10-15-2010 09:18 PM
53 willys
38
11-06-2008 11:18 AM
nitrous
10-21-2008 04:42 PM
