Ran on the Dyno today...
Old 11-08-2009 | 11:54 AM
rockcrawler304's Avatar
NICE numbers Mark!!
Congrats!
Old 11-08-2009 | 12:53 PM
madhat's Avatar
Administrator/Jarhead
Originally Posted by jlibert
congrats? regular old revo program? or revo tnt/tntr?
The current TNT regular.
Originally Posted by gsdog1
Just as a point of reference, I am running the stock gasket with standard ARP studs torqued to the spec and hit over 80 pounds on the 04.5. The cam really helps with drive pressure.
With the gas things change a lot though, as am sure you are aware. May need to talk to some of the gurus in terms of timing and using the NOx.
Yeah, the gas really changes a lot! That was probably was not the most intelligent thing in the world to do, but go big, but go home!
NICE numbers Mark!!
Congrats!
Thanks!
Old 11-08-2009 | 02:18 PM
soulezoo's Avatar
DTR 1st Sergeant
Congrats Mad; nice numbers!
But you lifted the head at that power level with ARP 625's??
I lifted the head about that level with the standard 2000's...
I've seen 625's hold 1k with spray...
No matter... enjoy your conquest!
Old 11-08-2009 | 02:22 PM
madhat's Avatar
Thanks! I'm gonna check the torque on them when I get a chance...
Old 11-08-2009 | 05:27 PM
king d's Avatar
congrats on your numbers.the should have no problem with the 625s and nos .i run 3 big shots on my setup with 625s and they have held well...
Old 11-08-2009 | 07:27 PM
O.T's Avatar
O.T
"Just the standard ARP 625's"
Mad may mean he is running the ARP 2000 not the 625's?
Old 11-08-2009 | 09:27 PM
madhat's Avatar
No, they are 625's. Like I said, I need to look up the tq numbers on them and check. Might play with an injector I have tapping while I'm in there...
Old 11-09-2009 | 06:43 AM
Jason_K's Avatar
Nice numbers and good looking family Mad. Congrats on both
Old 11-09-2009 | 07:11 AM
madhat's Avatar
Thanks, buddy.
Old 11-10-2009 | 07:21 AM
Bswope's Avatar
Congrats on the #'s MAD!!
Do you by any chance have a DP gauge on the truck?
How is that 16ss housing keeping up with temps... Id imagine in the 600hp range its doing great....
Did you try any runs with just straight water??
Old 11-10-2009 | 07:29 AM
madhat's Avatar
Thanks!
No, I don't. That's on the list. You know how that goes!
My turbo is great, it will hold about 550 hp all day with no problems. When I crank the smarty up, I can peg that 1500 * gauge in about 3 seconds. I've got a lot of fuel...
I usually run straight water on a normal basis, it works good in keeping the temps down. I've kind of outgrown that pump, but when I'm running less than 30 lbs of boost, it works great. On the dyno, I don't think that pump can overcome the boost pressure. My first run was with the snow kit off, and the 2nd, 3rd, and 4th runs was with it on. That 4th run, I had David build some boost before he hit the button.
getblown5.9
08-13-2007 10:52 AM
LanceD
02-16-2006 05:31 PM
Asher
01-03-2006 11:14 PM
Rob Ez
10-13-2005 06:03 AM
Quick Reply: Ran on the Dyno today...
