RAMIFIER for 04.5
Old 09-13-2004, 01:56 PM
BCarmicle's Avatar
Has anyone compared the Ramifier to a EZ? I'm running the EZ and have been wondering if the Ramifier comes on stronger on bottom end than the EZ.
Brandon
Old 09-13-2004, 02:10 PM
doug's Avatar
I would certainly expect so. the Ramifier does something that the EZ cannot do: it fools the ECM into fueling stronger at the low end by presenting higher than actual boost pressures to the ECM. Ramifier and Volumizer are the only boxes I know of that do this.
PowerstrokeThis: wow! I put the speed loader on my truck and easily ran pre-turbo temps up to 1400. meanwhile my post turbo temps were 400 degrees cooler than pre-turbo temps, at 25 psi boost. That of course was with the August 2004 Banks calibration of the six gun. If you consider 1400 degrees differential temperature across the turbo and Banks de-fueling at 1300, you could easily acheive 1700 degress pre-turbo. thats higher than I want to go!
Old 09-13-2004, 02:35 PM
Fummins's Avatar
Originally posted by PowerstrokeThis
sad the was I had the egt probe set to post turbo
Huh?
Old 09-13-2004, 02:53 PM
doug's Avatar
The speedloader requires a thermocouple to operate (needs to see a minimum of 200 degrees), and it is calibrated to de-fuel at 1300 degrees. to defeat this defuling, he put his thermocouple in post-turbo as i suggested, so that the speed loader would run but not defuel.
he is sad because he was not able to go higher than 1300 degrees post turbo.
Old 09-13-2004, 03:33 PM
Fummins's Avatar
Gotcha
joeservo
182
06-17-2004 03:54 PM
reb0957
03-25-2004 09:09 PM
ssteve
03-22-2004 04:23 PM
Fummins
03-14-2004 11:10 PM
Reptar
03-11-2004 12:00 PM
Quick Reply: RAMIFIER for 04.5
