Rail pressure readings (which gauge is best) and does a smarty affect the reading?
Just curious what normal rail pressure readings should be? idling reading and WOT reading. (on a 305/555 engine)
Also, how does a smarty affect either of these two readings? (idling and WOT).
Who makes the best gauge?
DTR 1st Sergeant
Smarty affects rail pressure by draining it.![guitarist](https://www.dieseltruckresource.com/forums/images/smilies/guitarist.gif)
Otherwise, only the beta 4.2-4.4 files play with pressure.
Best gauge is more a function of what you like. Among the major mfgs. there is not enough difference in quality or functionality to argue about. The electronic digital (vs mechanical) gauges I think are easiest to install though.
Rail pressure on an 03 at idle is about 5200-5500, the Smarty affects the rail pressure by bringing it up much sooner than stock programming. THe rail pressure will not be raised much if any, but it will bring it up much sooner in the rpm range. Depending on the smarty version, max rail pressure will vary from 21000-24500psi.
I think they all install the same and take readings pretty much the same. You really just need to decide how much $ you want to spend and if you would rather have analog or a digital read out.
i just got a qzilla gauge, easy install. i also got the fuel pressure kit to go with it. pretty good deal for $200 from dtr store. 5k-5.5k at idle 8k-12k crusing at 70mph. this is running all stock
mullishacrew
03-18-2012 12:41 PM
sallyman1
08-17-2009 11:09 PM
Igor
12-27-2008 11:42 AM
5.9Excursion
03-13-2008 10:56 AM
BlueDually
01-11-2007 03:08 PM
