quick tnt/r question
What kind of power do you think you have now, smoke19D ?? And what settings are you playing with on the tnt/r?? I'm going to hunt down a usb cord so I can load my R into my pod then load it in my truck, right now I'm running a pmt w/cl and running high egt's (700-800 @ 50-60mph). It's higher now than when I was stock with cl......... I was advised not to play with the wastegate on the twins....
as far a egt's, it's hard to get a consistant # because there's not a straight or flat road anywere around here!!
i would be extreemely happy to be at the 600hp level, however i think the turbo may be holding me back
rock on buddy!! i definitely think it's been worth the wait!!!
How does a person open and save the attach. tnt/r from Bob?? I've read something about unzip but what/where the heck do you do?? As anyone can tell, yes I'm not a computer whiz....any help will be appre. THANKS
try this link https://www.dieseltruckresource.com/...marty+download i followed the instructions to a "T" and it worked perfect. thank god for that thread because i'm no computer genius either
i've only driven it 3 times since loading the R and i set it almost straight to kill (sw9-tim2-tq4-rp-2,stock revs and PoD 99). being that i have a manual, i don't think the shift limiter has any effect so i've left that stock as well. it seems to pull hard through the entire rpm range and the SOTP seems a good bit stronger
Jason.... might be time to upgrade to a 64 wheel?????
that's what i was thinking the other day so i called HTT and asked them about it. for $400 it's a pretty cheap upgrade. they also said that with the upgrade would come another 1yr warranty!!! i may have to take advantage of that when i get the $$$$ i'm pretty sure that size of turbo would put me past my goal of 600hp too
I respectfully disagree, My truck does not respond well to the odd #'s of TNT, but #6 TNT is stonger than any of my 4.2 tunes, and it does it with less smoke, and cooler egt's.
I know the original ? was TNT-R, but as I understand the TNT-R's difference is fueling to 4k?
