quick DD clutch install question?
does the new flywheel on a DD clutch bolt right to the crank with NO spacers??
do I remove the plate that bolts to the crank and then bolts to old DMF??
I will try and get a pic...
Mark with mine it came with a spacer to go behide the flywheel, but we did another fellas and had to use the flex plate lookin thinger that was behind the DMF as his spacer!
What clutch do u have?
I am installing a HMR street drag...
the instructions dont say nothing about it..to me it looks like I would NOT use it..but I wanna make sure BEFORE I put it all back together...
If u can, hold the flywheel up to the crank and run the bolts in, if they bottom out and need to go in farther then id say u probably need it, but if they dont bottom out then id say u dont need it!
Mark I'm not sure on the thickness of Haisley setup but south bend gives you a spacer to go behind the flywheel along with new bolts that get torqued to 40ft/lbs I believe. Hop this helps
45ft/lbs is the pressure plate bolts, and the flywheel is 90-100ft/lbs. I took mine to 100ft/lbs.
madhat's monkey boy...
Not sure. But it some how has to loop back to the cooling sytem some how. Lazersmith has a system that he has created to not allow the pulgs from blowing due to The high pressure of the cooling system at higher R's
