Questions about EDGE EZ box
hey guys thanks for all the info. i have my EZ set at 70 HP. I will be buying a boost elbow very soon and gauges are next on the list.my friend that i got it from looks like he had it set on level three.so how much power is level 5 soposed to give me. allso how hard would it be on my injectors.alllso here is the web address for the Edge EZ instructions.allso i will be stacking my truck with a tst box. thanks again Bobby Miller
http://redhat2.admarkonline.com/~edg...manual-156.pdf
Mopar,
The EZ on 70hp and above is pretty tough on the injectors. Don M reported major injector bore erosion with little as 20k miles with the higher level. Level 3 is not as bad and level 2 is ok.
My guess level 5 is around 80hp
MikeyB
MikeyB
On level 5 you will probably blow the pressure sensor gasket. My 03 did. It is only a $1.00 part but you do end up with leaking fuel. The truck was fun to drive but it is definitely not good for your injectors. That's why Edge doesn't advertise that setting. Some of the first boxes even had a setting #6!!!!
Havic801
11-16-2011 02:34 PM
Jvenne86
18
01-08-2007 10:19 PM
04ctd
10-05-2006 08:27 PM
Mopar72
04-14-2006 06:19 AM
coobie
25
02-23-2005 04:05 PM
