Question for those running big tires
Hey guys, I'm curious as to what kind of mpg and performance difference there is between 35" tires and 37" tires. Is it a lot or barely noticeable? I will get the 4.10 gears and a six inch lift. What thoughts do you have on 20" wheels.
your question is lacking info we need to answer what you ask.
what gears do you have now?
what tires do you have now?
what mods have you done so far?
what are your plans for the truck in the future?
what do you use the truck for?
I presently have the 3.73 gears but am planning on installing 4.10s soon. The only towing I do is about 3000# six times a year. I am mainly running empty on the highway and a little city.
35s w/ 3.73 and 37's w/ 4.10's are a good combo if you have a little extra power. Stock power...you will feel it.
Between the two combos above...depending on driving style and location...you may only loose a little. Your lift height will cost you more than the tires...
If you are a short box...I personally would keep your present gearing...run 35's (no opinion on whether you are a big wheel versus normal wheel type dude...I am a normal wheel dude) and get only a 4-5" lift. That will give you an awesome truck...very drivable and avoid many of the issues with larger lifts and even worse mileage.
Long box...build it like mine or a few others on the site that have 37's, the correct wheels, 4.10 gearing, anf only 4-5" lift. The longer the truck...the lower it looks.
JMHO
JMHO
I would personally stick with the 3.73 gears. I am running the 20" wheels/35" combo and have 4.10s. I would personally like a little higher gear on the highway to yield better fuel mileage.
Also, if you ever plan to drag race and put your stock tires and wheels back on then you will be restricted by the rev limiter if you have the power to get there.
Brandon
Brandon
i too would stick with the 3:73 gearing, i have the 4:10's and 315's on my truck.i love the gearing, but on the highway, it revs out a little too much for me. i think that the revs would drop a bit more and be more normal for cruising on the highway, and i don't think i would notice it much around town. lots of bottom end to these things, so gearing not so important when you don't do alot of towing, which is my case .
I have a 2005 w/ the G56 and 37's. I am definately keeping the stock 3.73 gears. The acceleration is just fine and the highway rpm is much more reasonable. With the stock tires, I was at 2350 rpm at 70mph. Way too high for me and any kind of fuel mileage. The engine is stock for now and turns the 37's just fine. If I had the NV-5600, I still would recommend the 3.73's.
J.R.
Denver, CO
J.R.
Denver, CO
BC847
07-02-2009 03:26 PM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
tobyw
18
03-06-2004 06:42 AM
