Question for Smarty / Quadzilla X2 stackers.
Someone help me out here. I'll be stacking my new Jr. with my X2 Std. soon and would like to know which X2 program everyone is using. Do I need the pressure only with or without boost fooling? The Jr boost fools also, right?
I am running the x2 race on level 2-3 and the Smarty(not jr) on sw#5....I love it egts seems real low..smokes thinned out some but it still smokes.....I just downloaded the "stack" tune for the X2 and thats what I use.
I love this stack altho it is the first stack I have ever done...the X2 and smarty seem happy together...makes really smooth neck snapping power!!!
I need a fuel system and clutch wanna know what puting this much power to the ground feels like!!!!
alright pauly. here goes.
When i am running Smarty and Quad x2 only, smarty wild on 9. X2 has race smoke program loaded. i need the additional timing of the quad at that point. top power is 510hp
when i add the tst to the mix, i put in the x2 stacking(pressure only) file since the tst does enough timing. the difference equates to around 30 hp for me and 100 ftlbs more when stacking the 3 of them. top power then is 543.
if i had more injector it would be higher.
i have ran the race smoke, standard race, stacking, and the race/mpg file. they all work well with the smarty.
i ran it with my sps62 and now the twins, and nothing funny. i build as must boost as i want.
do you mean surging, spiking, low boost, ?
both my quad and smarty boost fool. no troubles ever
Cool.
No. I just want to make sure having two boost foolers isn't gonna throw codes, or cancel each other out, or who know what. Sounds like its a non-issue.
yeah, you'll be fine if the turbo you are running has an actual wastegate. when running both foolers and a bunch of fuel i could blow past the gate setting and then it would settle down. and the smarty only fools with an aftermarket turbo program if i remember correctly.
you running a stock hairdryer?
sCreamin400
14
10-28-2009 05:46 PM
Smokin98.5
0
05-29-2008 05:35 PM
BossHogg
04-25-2008 05:42 AM
LooseBoltsRob
17
06-10-2007 08:52 PM
brickenbone
09-05-2006 07:25 PM
