Question for Quad(boos Fooler)
Old 10-17-2006 | 04:55 PM
RAMROD2006's Avatar
Quad I am buying a bd super b turbo, and I am going to need a boost fooler, will yours work with this turbo? Plug in the wastegate?
Old 10-17-2006 | 05:23 PM
qzilla's Avatar
The boost fooler really has nothing to do with any particular turbo. The boost fooler simply keeps the ECM from seeing an overboost condition and setting a check engine light. Now on the new model truck the wastegate is also opened based on boost pressure, so when you add the boost fooler it keeps the wastegate shut allowing you to make as much boost as you have fuel for.
In your case the boost fooler will keep the light off and your boost psi will be dependant on how much fuel you have to burn.
Killdmycobra
11-12-2010 06:15 PM
Rollin' Smoke
23
06-26-2007 10:04 PM
rustyshakelford
13
01-14-2007 04:04 AM
DODGE 92
06-04-2005 11:07 PM
