Question for outlook owners
I have been reading that stock the boost is about 30psi my outlook monitor has never shown me over 18psi is this so it won't throw any codes?
Thanks in advance
Thanks in advance
The Outlook in my truck runs higher numbers because of the boost elbow from an EZ. With the elbow and nothing else I see 36psi on the Outlook. With the BDDL on Extreme I see 40psi. I have no idea why yours truck is showing such low boost numbers. What does the Outlook show at idle? Try driving up a good grade with the hammer down and see what boost you see then. Good luck.
Originally Posted by leonesm
I max out at 28-29 lbs of boost. If yours is only showing 18 something is wrong
You guys at 30-34 are reading absolute pressure (which includes the atmospheric 14.7psi pressure).
If you were truely running half boost, you're truck would barely get out of its own way.
At wot today with the plow on going up a hill I hit 18.7 it idles at .9 to 1.4 the truck runs strong so I think it is running correctly. I will try to call bullydog in the next couple of days and see what they have to say, thanks for everyones input
You guys are having problems with your outlooks. Maybe bad connections or grounds.
I would definately cal 866-bullydog and talkt to someone in tech support and get those fixed.
kev94mx
19
06-15-2007 07:33 PM
BigJohnston
03-15-2007 08:21 AM
essgeetee
06-03-2006 12:24 AM
