Question on F.A.S.S operation
Old 10-25-2004, 12:07 PM
Don-T's Avatar
My FASS is fairly quiet. I used rubber grommets to run the mounting bolts through to isolate it. I can hear it before I start the engine but not when it is running.
The problem I am having is siphoning fuel out of the tank when draining the water separator or when trying the change filters. I have been disconnecting the QD at the tank to stop it. I am going to install a valve on the suction line so I don't have to pull the QD loose. After that I think I will remove the QD because I too am pulling air past it.
Old 10-25-2004, 05:03 PM
Haulin_in_Dixie's Avatar
Just change the filter with less than half a tank. How often do you change it?? I have changed mine twice, but never have had one show as restrictive in near 100,000 miles.
Old 10-26-2004, 07:21 AM
Don-T's Avatar
I have pulled the filters off two times. Once to remount the unit with the rubber grommets, and once when the unit quit working and I had to replace the motor (replaced under warantee) . I put new filters on the first time because they both collapsed when I was trying to get them loose.
charles.sulliva
12-26-2010 06:46 PM
MrKen
08-25-2008 05:36 PM
truckbouy2
03-29-2008 10:48 AM
NJMurvin
10-14-2004 12:01 PM
Contractor
10-07-2003 07:59 PM
Quick Reply: Question on F.A.S.S operation
