Question on EGT Installation
Yeah, I agree. I don't think I have ever heard of anyone who has actually trashed a turbo from installing a probe, and we are all probably a bit paranoid.
After being really careful cleaning and regreasing the drill and tap frequently, I was surprised that I did get some metal grit out with the magnet, but I bet bits that small would have just passed through the turbo anyway.
Also, when it comes to how far to go in with the tap, I'd suggest trying the pyro fitting periodically. Stop when the fitting will tighten at the same depth as the manifold is thick (or just a bit more)- so all the threads are engaged but the fitting isn't needlessly sticking out in the exhaust flow...
I'm no expert, but that seemed to make sense...
well a hole in the manifold is just an exhaust leak so it is not loud really. it just sound like you have bad header gasket or something. so it is louder but nothing crazy.
I used nothing to seal the probe fitting into the manifold. I just tightened it up and it sealed.
Originally Posted by hognutz
I used nothing to seal the probe fitting into the manifold. I just tightened it up and is sealed.
I mounted the gauges today, will drill and tap for the pyro and the boost tomorrow. I'll have to wait until Monday so I can get some tranny fluid from the dealer before I break the tranny line and put a swege lock into it. Wish me luck.
Phil n Az
06-03-2006 11:42 AM
e037383
05-16-2005 11:46 AM
Cummins600
10-03-2004 11:13 PM
betsycam
09-09-2004 11:29 AM
