question with Edge EZ...
so as i understand it, the Edge EZ does not boost fool, correct?
so what is the little elbow they supply with there box that screws into the turbo?
if i buy a quad boost fooler do i still need to buy a boost elbow? or will the one from edge work?
will a quad boost fooler work on all 3rd gens? or is it specific to 03-04 and 4.5-07?
thanks!
thanks!
The EZ will not like fooled boost because it not only fools the boost it also fuels using the boost for a reference. I don't know how critical the boost reference is since it's ony a pressure box but you could try it with and without to see if you already own it. If you don't already have the Quad boost fooler then I wouldn't worry about it.
rockjeep73
03-25-2005 03:34 AM
Hoss
13
06-18-2004 06:14 PM
powerwagon440
01-20-2003 08:50 PM
