Question about smarty?(ecm)
I let my buddy use the smarty to go pullin the other night, he had it stacked with the TST, he usualy runs a diablo with it but wanted to try my smarty, well he used it run great second place.... a few days later he calls and says his diablo or crazy larry won't load anymore it says can find vin, has anyone else had a similar problem, if so what does he need to do?
Thanks guys
Chad
Thanks guys
Chad
he needed to be sure he returned the Smarty to " stock " when he removed it from him truck.
He also needed to be sure to do the same when he removed the BD from his truck to load the Smarty.
what happin is the smarty puts the newest flash from dodge , diablo is a little behind , his tunner probly says ur truck is not in are database . the calibration ID number is to new for the diablo. i got the same problem . hopefully diablo will get the new update. or u can get some one at dodge to reflash with old software . tell him to call the diablo pred. tech line they will explane to him
6spd05Dually
03-12-2011 12:19 PM
jrussell
17
09-17-2007 06:38 PM
Ohio Joe
07-12-2004 12:13 PM
