Question about leveling kit
Old 11-08-2003 | 08:42 PM
Chance's Avatar
If I install a leveling kit on my 3500 SRW 4X4 Quad will I have problems with getting the steering wheel re-aligned? The leveling kits I've seen only include bushings, no pitman arm correction. Is there enough factory adjustment to correct the alignment? Which 2" kit is better? Daystar plastic? or Tough country steel? Also which Rancho 9000 part numbers would I need for the front and back?
Thanks.
Old 11-10-2003 | 07:54 AM
turbov6joe's Avatar
Re:Question about leveling kit
Personally I would go with the steel. I've talked with folks that said they're plastic spacers crushed or fell apart after time. If you crush the metal spacers you have BIG problems!
sgtdiesel
25
06-26-2012 03:37 PM
andyt
01-23-2006 02:39 PM
One Way
12-31-2005 10:39 PM
P.J
02-19-2005 09:01 PM
rattle_rattle
07-09-2003 08:46 PM
