Quadzilla xzt issue????
I have a 2007 5.9L cummins. I put just a quad xzt box on today. Turned the key on and it blinked green, orange, orange (indicate 04.5-07 standard module) then when the power level status came on it was set at red (which in the manual indicates level 3 100hp, 200 ft lbs torque) I was under the impression the plug in box was only supposed to be level 2 (60hp, 120ft lbs torque). I really want it on level 2. Anyone know whats going on here?
Nope, not an issue.
The XZT modules were changed up slightly when the Commander came out so that they are compatible.
It is still 65hp but, it is set to level 3 so that when you hook the Commander up you have 2 lower levels plus an off position.
sCreamin400
11-02-2008 01:46 PM
Batts
20
09-12-2005 07:39 PM
wdbates
38
08-10-2005 07:59 AM
MikeyB
04-20-2005 01:24 PM
onesourceoil
28
04-08-2005 08:13 PM
