Quadzilla Rail Pressure Gauge
Ok, so I know that there have been some problems with the rail gauges, and I though I read that they had the problems fixed. So my question is are they working good now? Also I thought that they could be purchased from the DTR store but I did not see them there. Is this a good idea, or are there better options for rail pressure and fuel pressure? Thanks.
My Quad II standard came with it and absolutely no issues with it. Had it for over a year.
It's this one: http://store.dieseltruckresource.com/xz2ad10mo045.html
Does boost, RP, coolant temp, and power level and has downloadable tunes updates via USB.
That has also now been remedied but, will come out as a new part #. We did this for a couple of reasons. 1.) the new part has a new small additional piece of hardware to install along with it 2.) to be able to keep track of which ones are ready to use the transducer and which ones will need an adapter.
The reason for the adapter is we wanted to provide a good fp solution to all the guys who have the older versions of the guage instead of leaving them high and dry!
No they are not fixed. Mine has been faulty for about 6 to 7 months. Quad keep saying a fix is coming but no luck so far. Been way way too long!
Quad,
How do we order "the fix" for older units? I tried the HD Sender but it didnt fix the fp issue (reads all over the place, but mostly low (5psi with a 30psi spring on my ad150))....
You gotta wait until we release a part# first!!
We have a solution but, it has not been mass produced yet! It takes a little time to ramp up production.
I don't have a time frame but, in the next few weeks we will have information available.
Long story short, the originals had some issues, we fixed that but, now they are discontinued. They are discontinued not due to problems but, the lack of a way to use our new fuel pressure transducer along with it.
Of course, please keep us posted.
So for those of us with the older gauge, we'll be able to purchase just the new transducer and adapter to have the fuel pressure function working?
It will be just like the Commander and will require a simple 1 day turn around.
D45
15
07-08-2008 09:45 PM
sallyman1
03-22-2008 05:46 PM
mopardamo
02-10-2008 07:04 PM
rattlbox
09-04-2007 02:20 PM
