Quadzilla Dyno numbers
Old 07-19-2007, 10:17 AM
DTR Detective
steelblitzkrieg's Avatar
Has anyone dyno'd a stock Auto 06 with just Quadzilla Standard on any settings, curious what the real world rear wheel numbers are?
Old 07-19-2007, 10:46 AM
dodgezilla04's Avatar
sailpipes dynoed his 04.5 manual stock with quad race 419/910 at bd last october
Old 07-19-2007, 11:37 AM
Dodgezilla's Avatar
My 03 SO running a Quad race stacked with a Van Aaken C3.2 only made 341hp/714tq....
Old 07-19-2007, 12:16 PM
TJBUGGIE's Avatar
Dynoed my 05 with the Quad race, 421hp/740tq on the high setting.
Old 07-19-2007, 01:42 PM
#1, that was on bd's dyno, which is famous for being tough to get good numbers on.
Old 07-19-2007, 02:36 PM
Dodgezilla's Avatar
Old 07-19-2007, 06:39 PM
qzilla's Avatar
First off, 600 series trucks are way different. I would really like for everyone to understand you cannot compare anything from an 03-04 truck to a 04.5-07 5.9L truck.
Second, the toruqe numbers are different because one was a load dyno and one was an inertia dyno. At least that is what my money is on.
Old 07-19-2007, 06:46 PM
morkable's Avatar
I concur with that qzilla. BTW good to have you back around, havent seen you for awhile.
Dynojet (inertia dynos) will give you higher hp and lower tq numbers.. Mustang (load dynos) will give you lower hp and higher tq numbers
A mustang dyno is IMO the best dyno to get real numbers for a diesel truck.
Kevin
Old 07-19-2007, 06:49 PM
$oC@l CTD's Avatar
That sounds a bit high #2 but i'm not going to be the one to say it...................
I was thinking the same thing though...My Edge Hot Juice with Attitude/Diablo Sport Power Puck combo put down just 5 more hp and 30ftlbs LESS torque?
I'm not trying to stir the pot, I just don't understand...were those numbers off a Dynojet or something?
Old 07-19-2007, 07:08 PM
Dodgezilla's Avatar
Old 07-19-2007, 10:55 PM
mustang dyno. with my slipping clutch at the time i got 389hp, 910. here's a clip from the results sheet of the internet. #41
36 Dabin Killie 02 Ford Exhaust 203.3 474.5
37 Bob Dewitt 92 GMC Lots of power 370.2 864.1
38 Malcom Cross 92 Chev Cummins w/power 472.0 1101.8
39 Lloyd Vaughan 06 Ford Stock 243.7 568.8
40 Chris Stieh 04 Dodge Turbo, Chip, Intake, Exhaust 389.9 910.1
41 Brandon Miller 04 Dodge Chip, Intake, Exhaust 418.8 977.6
42 Mike Gunn 06 Ford Stock 264.8 618.1
43 Dean Nichols 89 Dodge Fuel pump, Exhaust 220.9 515.6
44 David Quinn 95 Ford 366.5 855.5
Old 07-19-2007, 11:07 PM
qzilla's Avatar
I am just telling you that a Race box will easily put down over 400 rwhp on a 600 series truck.
I will also tell you that while the normal Edge box runs good, our Race box will definitely out run it. The Hot makes them closer.
There is a thread on another site that had a guy make over 400 rwhp with a race box on WVO!!! he also made nearly 420 rwhp to the tires.
I have seen as high as 440 with some wild programming. And no, don't ask for it. It might be made available in due time!
Morkable,
I have sort of been here, I have been running like a chicken with my head cut off. It is bad when you leave work at 10pm and your list of things you did NOT get done is as long as your leg!
Old 07-19-2007, 11:27 PM
morkable's Avatar
LOL,, I know how that works,, I fix computers for a living, and it is a never ending story..
Kevin
Old 07-20-2007, 06:51 AM
Dodgezilla's Avatar
Old 07-20-2007, 09:51 AM
Fire Rescue124's Avatar
not to change subjects but i have a chance to buy a quad box for my 04 the guy wants $150 for it. i am looking at getting a smarty around the end of next month so should i even buy the quad? I don't have gauges yet so should i wait till i get atleast a pyro or can i chip it low and not worry i do have a straight so would that keep my temp lower? Thanks, guys
Quick Reply: Quadzilla Dyno numbers
