Quadzilla commander and smarty?
I tried the search function but had no luck (may be I'm a dummy lol) so i will ask here.
will the quadzilla Commander work with the Smarty? I see them listed in the store but I did not see where they were compatable. I found one on E-bay and it listed a lot of chips, programmers and modules but nothing on the Smarty.
thanks in advance.
thanks in advance.
Yep. The Commander is setup so that it will work with just about anything. Since the Smarty is a programmer, as far as installation is concerned it would be like adding the Commander to a stock truck.
Yes, The Quad Commander is a digital gauage that allows you to set parameters for defueling to prevent engine damage. Tha Smarty is a programer.This is not a stack ,it is gauges and a programer.
Did you mean A quad Commander? there are other Commanders.
I'm just talking about the guages portion. I am not looking to stack, just to monitor what everything is doing. I am going to go ahead and get it with the fuel pressure option. (I think)
Anyone running one and how do you like it?
Couldnt be any happier with mine. Easy to read, easy to work, and easy to install. The hardest part of the install is drilling and tapping the manifold for EGT, and that was easy!
M Sandt
M Sandt
plug ugly
06-05-2011 03:22 PM
norcaljr
13
08-05-2008 10:13 AM
JHew84
03-05-2008 12:32 AM
shskr
02-23-2008 03:12 PM
stock03
11-09-2006 11:27 PM
