Quadzilla Commander Now Available!!!
#61
I have made a couple of posts about the fuel pressure sending units. The manufacturer of them had some wrong specs in them and it is causing them not to read 100% properly in some instances. We should have a downloadable update next week at the latest for this. You do not need to ground the sensor. Long story but it is not needed.
THe oil and water temps will take just a second to reflect actual temperature of the water or of the oil since the sensors themselved are going to be a certain temp before you start them. This is the same with a factory sensor, once the fluid is going over them they should be very accurate.
The 60hp setting is going to be really close with a touch more smoke on the bottom and it will spool every so slightly faster.
Max injection pressure is going to be between 26.8-27.3K depending on the factory sensor.
Race module should never exceed 26.5K
#62
Couple of questions, How does the fuel/rail pressure harness hook into the system? Do you have to T-tap wires? or hook into the CP-3? Also after reading the install instructions it doesn't mention how it gets Oil temp, and RPM readings. And lasly do you plan on an oil pressure reading feature? Thanks. Sorry if I missed some of this in the instructions.
#63
For the fuel pressure, you tap into the High pressure sensor, and you get a new low pressure sensor and banjo fitting to get that reading.
For oil temp, you either get tranny oil temp, or Oil temp.
I was thinking of getting a toggle switch and a second sender so I can toggle between tranny and oil temp.
RPM reading, its currently not used.
#67
#68
My Commander just came in the mail. This is going to be some fun and a great addition for my truck.
The tow module is the next purchase.
Just for a heads up Qzilla, I bought it off ebay, I would have got it here and supported DTR but the wording...."Delivery may take as long as 2 to 3 weeks". turned me off. Sorry.
I'm still happy to have the product, I hope the install go's easy.
#73
#75
