Quadzilla Commander fuel Presure kit.
1) What is the benifit With this kit?
2) What does it technically do?
3) Can I run it with my egde juice module?
4) Would it be benificial to run with edge?
1- Knowing your fuel pressure is helpful because if your lift pump is going out, you'll see it. Important because the injection pump relies on a steady flow of fuel to lubricate it. With the kit, you can also monitor rail pressure, which will be nice once you start running the Juice.
2- It's a sending unit that threads into your Cp3 (Injection pump) and reads the pressure coming in. The FP kit also taps a wire to read rail pressure.
3- I believe so? Shouldn't have any problems, but I have not dealt with the Juice.
4- Yes- The Juice will "Up" the pressure in your rail, which you'll be able to read, and the FP reading will let you know if running the Edge is demanding higher fuel volume (ie.. If you need to add a better lift pump, such as a Glacier Walbro or FASS.)
dodgediesel
12-05-2008 10:26 AM
sheriffav8r
31
11-02-2008 10:15 AM
norcaljr
13
08-05-2008 11:13 AM
truk
44
01-31-2007 01:01 PM
stock03
11-10-2006 12:27 AM
