Quadzilla Commander
Quadzilla Commander
I thought I would throw some pictures on here of the install on my Quadzilla Commander. Install was easy and took approximatly 45 minutes with drilling and tapping the manifold being the hardest part. I have a six speed so I used the temp sender for my oil temp instead of trans temp. I checked accuracy of the Commander against info in the PCM and it seems spot on. If I can help with any questions feel free to email or pm me. Dean
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Originally Posted by koogala
Good lookin install!
Quad, when willthe full-blown whistle & bells model be ready?
I am trying. Like I said the USB is holding us up. We are working as hard and fast as we can.
Thanks.....I used a bracket from a company called cell site that my local cellular installer had in stock. I think it put it in the perfect place for me and easy to get to with the six speed. Quad and the guys have definatly outdone themselves with this I think. The backlight is perfect.....screen is plenty large enough even when displaying 4 parameters. All of the connectors look top notch. The only thing I found is that the wire is too short if you want to use the temp sender to monitor oil temp. 1 1/2 foot of wire and some solder and I had the problem solved. Dean
I used the harness that Quad provided for everything except the oil temperature. There seems to be plenty of wire for all other connections and with some creative routing you can make it look good. The harness is made to fit all applications so there is a little extra wire length for the Dodge but it isnt a problem.
That line was originally intended for the tranmission and on the Dodge it happens to be further away than the Ford or GM tranmission port so it does have a little extra length to get to the oil temp port.
I like where you mounted it and that also is probably why the line is slightly short. From beside the A-pillar it should reach the oil just fine.
If it needs to be longer we will make an adjustment on the next run, we need some more 6spd guys to chime in!
Quad
One good thing about where it is, is that all of the connectors remain in the cab and away from the elements although the connectors look good and water tight.
I'm a 6 -speeder and DYING for this new toy !!! Any plans on making an A- pillar mount for that beast that keeps the handle ? Also will your Quad race get along with an Mp-8 ? Lots of enticing offers out there but I am holding off for you brother !!!
We are working on a couple of options for A-pillar mounting. First is a vacuum formed pod that works like the Attitude. Second is similar to the original design, but it should allow for mounting in the SRT Pillar. WE originally had a design for this and other single pod mounts, but the SRT-10 Pillar has a much larger hole than a normal vacuum formed pod. We were using a press fit and that won't work in the SRT pillar.
Mounting is a PITA, but our universal mount works pretty darn well, it just is not ON the pillar. You can put it right beside the pillar though. On the 2006 trucks there is actually a perfect spot for the mouting system beside the pillar because it is slightly lower than the dash that goes over the speedo.
Also the MP8 and the Race box will not work properly together.
Also keep in mind that if you have an MP8 the Commander will control it and allow you to defuel it as well.
Quad
Quad
Quad
norcaljr
13
08-05-2008 10:13 AM
admin
76
07-23-2007 10:37 PM
stock03
11-09-2006 11:27 PM
ptgarcia
17
05-06-2006 06:39 PM
