QuadZilla Adrenaline?
#106
They are both power wires, it's just one is for the TT. If for some reason it doesn't work one way (for TT) then just reverse the power supplies(fuse 28 and 42).
#107
directions are for 03-05...should be the same.
I'm assuming the directions have the turbo timer/module power wires backwards?.... which would mean I had the turbo timer powered up but not the adrenaline module itself.
I HAD the red wire on #42....red/white on nothing.
If I put the red wire on #28 and the red/white wire (after cutting t-tap off) on #42....I should be up and running?
#108
Yep, I believe that is correct. If it doesnt swap the wires, I had the same problem when i installed my on my brothers, but I cant remember what went where?
#110
#114
the directions that came with it says:
1 long red with fuse tap to #42 (from data link)
1 short red with fuse tap to #28 (from main plug at box)
red with white stripe for 06-07 trucks
#116
Do you have two red wires one with a fues tap and one that could be hooked to the battery? I think remember there was a note on a small piece of paper that said to run the TT wire directly to the positive battery post.
#117
tryNto...it sounds like the red/white wire for our adrenalines has a t-tap on it, but shouldn't.....
we don't have the wrong module, or we would have recieved a plug for the dianostic port under the dash. (06's)
#120
I didnt use my TT so I just hooked it up to fues 42 and 28. I wish I had mine with me so i had something to look at. If you dont get it tonight. Ill look and it tomorrow and try and help again.
