QuadZilla Adrenaline?
Old 06-13-2009, 09:14 PM
  #151
tryNto's Avatar
is that the low side fuel pressure?
either way those #s are way off
Old 06-13-2009, 09:31 PM
  #152
qzilla's Avatar
You have the transducer on the input side not the return side correct?
Old 06-13-2009, 09:43 PM
  #153
tryNto's Avatar
I tried the update like you said, it says "no commanders were detected"
now what?
thank you
Old 06-13-2009, 11:12 PM
  #154
clarson80's Avatar
I have it on the side closest to the front of the truck.
BTW--of course I turned it up and jumped on the throttle...just once
I'm new to 3rd gens...is that "timing rattle" I heard? I think it was around 2100-2500 rpms or so. (didn't catch the tach...busy watching black smoke ) It won't make that sound stock.
Old 06-14-2009, 12:08 PM
  #155
tryNto's Avatar
clarson80, glad you got yours working...
I didn't do anything other then you did, but my Pulse will not show a display.
Tried all of Qzilla's suggestions.
guess I'll be calling Quad on Monday to get a different 1.....
Old 06-14-2009, 10:54 PM
  #156
qzilla's Avatar
Did you try to download an update into it?
Probably a lot of things you are hearing! More boost, more timing, more rail pressure etc! These motors are so quiet that any little changes make a big difference!
Old 06-14-2009, 11:50 PM
  #157
tryNto's Avatar
Yes I tried everything.
its not recognized by the software.
just a back light when connected by USB, just like in the truck.
I removed it all from the truck and put the MM box back on for now, truck runs fine just like before...
can i just return the whole thing to you and you can send me 1 that is tested good before shipping? Please
Old 06-29-2009, 08:48 AM
  #158
yelloz28's Avatar
Just put on the latest pulse update this weekend and it seems to be working perfect.
Only thing I would change is I would still like the beep back for level changes Quad.
Old 06-29-2009, 08:59 AM
  #159
tcr
tcr's Avatar
Quad, can you let us know when to expect the Rail pressure to be accurate for 03-04s and when the stacking tunes will be available? Thanks!
Old 06-29-2009, 02:34 PM
  #160
RowJ's Avatar
In reading through all your posts, I cound not help but smile!
Almost word for word scenarios that we went through with the 2nd Gen Adrenalines.
I feel for your frustrations.... can only tell you Quad got it all worked out for us.
The Adrenaline is the hottest 2nd Gen box out there. And all the Pulse readouts are spectacular!
They must be even more phemonenal on a 3rd Gen?
Took a while... Beta Testing and "on the market" trials before all the kinks were gone for everyone.
But was worth the wait!!
Good luck guys!
Someone asked for ideas on mounting Pulse. I kept my a-piller gauges and mounted pulse here.... Some don't like it but works great for me!
RJ
Old 07-02-2009, 05:29 AM
  #161
tcr
tcr's Avatar
Quad, Can you update me please???
Old 07-02-2009, 11:02 AM
  #162
qzilla's Avatar
It is accurate. 03-04 rail pressure = the same map as 04.5-07, the 04.5-07 just runs higher.
Old 07-02-2009, 04:08 PM
  #163
tcr
tcr's Avatar
Nope, it's not. An 03 does not idle at 6500-7000 psi RP(they idle at 5000-5500psi), get w/ Jeremy he is seeing the same on his truck.
Old 07-02-2009, 06:25 PM
  #164
qzilla's Avatar
I was just in an 03 today and it was about 5300 at idle? I will see what could possibly be wrong with it. If he has one that does it, then it will be easy.
You have a beta board so maybe there is a wrong value part or something? I know we had to change a small part out for the FP reading because there was an error on the bill of materials when the first ones were built.
Old 07-02-2009, 07:05 PM
  #165
tcr
tcr's Avatar
10-4, just let me know please.
Quick Reply: QuadZilla Adrenaline?
