Quad X2 and Commander install questions
Old 08-06-2008 | 10:40 AM
estesbubba's Avatar
I have a Quad X2 Standard with Commander and pillar mount ordered and have a few questions. After reading the instructions from the Quad site on both, it appears they both have wiring harnesses to connections on the engine. I'm assuming I don't use both. If that's true, do I use the X2 or Commander harness? Do I run the harness to the Commander then connect the X2 to the Commander?
Should I use dielectric grease for the connections?
Any advice, links, pictures, tips, etc. would be appreciated.
I can't wait to get it installed before pulling my 5er to Estes Park.
Thanks!
Old 08-06-2008 | 11:49 AM
QPTRR's Avatar
The X2 and the Commander harnesses will both be used. The Commander harness will connect to a couple of the same connections the X2 does but the X2 harness already has the quick disconnects on each plug to connect the Commander harness to so that you do not have to tap any wires. You will have to drill and tap the exhaust manifold for the EGTs, and install the trans temp sender in the transmission for that reading.
Old 08-06-2008 | 08:02 PM
estesbubba's Avatar
So would it be best to install the Commander first then X2?
Old 08-07-2008 | 09:51 AM
iweb's Avatar
I hear ya, why can't there be one harness? Seems stooooopid to have 2.
Old 08-07-2008 | 09:56 AM
QPTRR's Avatar
You need to install the X2 first then the Commander.
TAS
10-02-2008 01:04 PM
D45
18
06-30-2008 06:35 PM
stock03
11-10-2006 12:27 AM
jaredb900rr
38
11-06-2006 01:09 PM
skydiver41
09-02-2006 12:53 AM
