Quad Standard box and Engine warning light?
G'day guys,
Ive had a Quad standard box installed for about a week, and last nigth I noticed the engine warning light come on. Naturally I'm concerned and being the weekend I can't get onto Quadzilla - any ideas??
Thanks guys, I'm probably being overly anxious...
Cheers
Cheers
See if you can cycle the key 3 times and get the codes. That will go a long way in diagnosing whatever the issue is.
Basically you need to turn the key to the full on position, but do not start it. Then turn it off. You need to do this 3 times pretty fast. Make sure the truck gets turned on first before you turn it off. You can do it too fast.
We will go from there.
Quad
Quad
I installed one on a guys truck and tried to start it, it wouldn't. Go back over the plugs and somehow I had one in backwards. Fixed that and it ran fine with the check engine light on for the next 8 or so starts.
engine light
Checking the codes with help you figure it out. I had this happen only once to me. I was idling while wife was in the store and decided to turn box on. Outside temps were below freezing at the time. So my thought is the grid heater was cycling at the same moment I turn box on. My codes were about voltage drops. I will not do that again.
Quad
Quad
did u turn the switch to the module real fast while driving, mine will though that code wen driving and turning the switch down fast, it ualy goes away after about 5 starts.
if you are getting a po148 check the tightness of the connections to the injectors. sounds funny buy very true. oh and the quad chip sell it unless you like wasting money on injectors.
Care to elaborate?
Originally Posted by Brad02ctd
have not heard this one before?? what do you know about them?
I hit him with some of Dr Evils patented troll juice and watched him scurry under the baseboard to die
He won't be answering any questions here on ANY subject his user name alone was enough to get him banned and the 2 posts he made were nothing short of "trolling"
tennman
08-16-2006 11:00 PM
Batts
13
04-30-2006 01:28 AM
Batts
04-04-2006 10:07 AM
badram
03-12-2006 02:47 PM
hoehand
14
11-16-2005 12:03 AM
