Quad Fuel / Rail Pressure Guage Installed!
Overall a good little unit....mounts easily on the steering column out of the way....only gripe is i wish the cable was on the left side of the unit to facilitate mounting on the dash near the pillar.....pretty easy to install...i was able to do it and i cant walk becasue of a knee problem....
On my truck with Beta 4.4 (Level 7):
Idle FP = 8-9psi
Lowest PSI reached (didnt floor it, but did get on it): 4 psi
Idle Rail = 9k
Max Rail = 25k
I would purchase this product again....great price point and good functionality!!! Happy i was able to purchase something from Quad as his participation on this site / customer service is great!
Idle FP = 8-9psi
Idle Rail = 9k
Max Rail = 25k
Idle FP = 8-9psi
Idle Rail = 9k
Max Rail = 25k
Idle FP = 8-9psi
Idle Rail = 9k
Max Rail = 25k
In your sig you say that you have a GDP-392 fuel system installed. If you see that low of fuel pressures it sounds like something is wrong. You should be in the 20+ psi range at idle and even up to 42 psi with the bypass valve tuned.....
I noticed the same thing. Those pressures look really low for a GDP system. They look about the same as stock...is your GDP pump installed yet?
That was also the first reaction for me, low FP. I like it but I put some flat black over the last couple inches of wire so it would hide it from being seen. I mounted mine right above the steering column.
White97GTVert
19
03-18-2008 03:03 AM
qwkness
31
10-05-2007 10:57 PM
out4elk
20
08-26-2007 12:53 PM
Dodgezilla
42
07-15-2007 07:06 PM
trik396
06-14-2007 05:41 PM
