Quad Commander - Vehicle setup
Quick question since I haven't seen this discussed previously.
I notice each time I return to the vehicle setup screen, the selected engine is always on the first option.
For those whose enigne is not actually the first option, is this what you see also?
I haven't gotten a copy of the pending code [yet] to see if this was addressed, so maybe it's corrected already.
Chuck
Chuck
Chuck, I see the same thing every time. When I look at other screens like the number of gauges, it's always on the last setting, example if set on 4, when I open it up again, it's set on 4. Very good question. Why does the engine type always return to the top of the screen when opened? ( It's a dam good thing, it doesn't say FORD at the top of the screen).
I don't guess I understand what is happening?
The Vehicle Brand is sorted alphabetically so that we do not offend anyone.
The engine model or year is sorted by year?
Is there something happening bad or am I just missing it?
Chuck
The menu never changes. It simply lets you select it then it is always selected until you change it.
The menus should always be the same from the first time you select a vehicle they should always be in the same order.
Vehicle Brand Should always be in Alphabetical Order
Engine Should always be in year model order.
lonewolf900
10-15-2009 11:17 AM
Mike D
07-13-2007 07:23 AM
stock03
11-09-2006 11:27 PM
