Quad BoostFooler Question
Old 04-28-2007 | 08:42 PM
Stevemil56's Avatar
I just put the boost fooler on my truck and it seems that it makes more smoke with than without. I am running the Tripple Dog and now with the boost fooler it makes smoke on all but the "Stock" setting. My assumption was that if the ECM sees less boost than actually created it will add less fuel than if it thought the boost was higher. I am new to the CTD world and need to be educated...
Old 04-28-2007 | 08:53 PM
belgianmagic's Avatar
BullyDog has NO Boost Fooling ... I would think you are confusing your ECM
Old 04-28-2007 | 11:58 PM
ptgarcia's Avatar
Originally Posted by belgianmagic
BullyDog has Boost Fooling already... I would think you are confusing your ECM
No, the Triple Dog does not have boost fooling. Not sure what may be causing the smoke, though.
Old 04-29-2007 | 12:53 AM
Jim Dynomite's Avatar
It will smoke in all settings if you get on it, or between shifts if you have a 6spd.
Are you seeing more than 35psi now that the boost fooler is installed. I was under the impression that the Outlook monitor takes its boost readings from the ECM. If you are using the boost fooler the ECM is only gonna see 35psi max. That's what I have heard.
As far as more smoke.............I dunno
............Jim
Old 04-29-2007 | 01:40 AM
973604x4's Avatar
how much difference is there? ALOT or just a bit more smoke?
Old 04-29-2007 | 01:49 AM
Lambo's Avatar
i have a Triple Dog and put on a boost fooler and i really didnt notice any difference in smoke or power....
Old 04-29-2007 | 01:50 AM
973604x4's Avatar
only power difference is top end pull...Have an EGT gauge? Boost gauge?
good ole boy
06-08-2008 03:21 PM
ryan 2500ctd
12-26-2007 11:29 AM
P.J
10-13-2006 02:54 PM
hllbllyhellion
08-19-2006 07:18 AM
BigBlue
09-07-2004 02:34 AM
