Qestion about stacking quad with my smarty.
Whats up guys? I'm currently gonna stack my smarty with my quad race box. It is an older xzillaraider box. Truck is a 05 2500 nv5600. My truck is mostly stock with gauges. I'm just curious what settings to use on the smarty with revo?
This is what Quad had to say when I inquired about HP and EGT difference if timing was removed................
"The box has a little less power and a little more egt. Not a ton of either but, it is a difference. It also tends to smoke a little less as it is basically pressure only and we also remove the duration. If you are stacking it works awesome!"
Just to make sure that is the timing for aftermarket injectors correct? Sorry I'm new to this stacking thing and I just dont want to damage my engine. Thansk for your help. Later.
I sent my Quad Race in and got pressure only on it. I cannot tell any difference at all, I am going to send it back, get it back to stock and use even #'s only, and if send Smarty back for POD, will still have a good skinny pedal.
Well I programmed my smarty for 30hp with aftermarket injector timing and ran my quad on 60hp setting and it runs great. The quad box really helps spooling the turbo and clears up the smoke. I like it. I'd like to try higher settings but i want to save my clutch.
I cant l any difference power wise with the X2 on. Yes, there is less smoke, and the timing sounds different, but nothing notable with the pedal. So I've just had a 600 dollar fuel pressure guage in my truck for a year now.
nvr-enuf
04-23-2011 12:43 AM
Big T
01-27-2008 03:51 PM
Big T
01-20-2008 12:18 PM
Big Smoky
06-25-2007 12:01 PM
CODODGE2500MAN
06-28-2005 01:22 PM
