Pyrometer Probe Install
Getting ready to install a pyrometer for my new Bully Dog Outlook monitor. I have two pretty simple questions.
1. What fitting is needed? 1/4" Tube x 1/8" NPT?? Where can I find one of those?
2. The instructions say to mount the probe pre-turbo. EXCEPT for the Dodge. BD recommends post turbo on the dodge. Any idea why that would be? Why would post turbo be better?
heres a link i like to throw around seems to make good sense, did mine with the engine running that worked out good for me others will disagree.
http://www.dieselmanor.com/diy/CMS3-gauge/G3image1.htm
Mlucas, you're right. Every other gauge I'v looked at - and every instruction set I'v looked at - says to installl the probe pre-turbo. So why does BD recommend post turbo install? What's differant about the Dodge and the BD? There must be something about it, or BD wouldn't recommend it.
I read the instructions for the Edge monitor. They recommend it be installed pre-turbo.
I installed 2 pyro probes with my Bullydog and monitor them both with the outlook monitor. One is pre-turbo like the picture in the above post and one is post-turbo in the cast elbow. The temps stay about 200* to 300* apart (pre-turbo is hotter) depending on how hard I accelerate. I don't think it will matter where you chose to install the probe, just remember that in the post turbo location the exhaust gasses will be a little cooler.
Your thermocouple should come fitted with a 1/8npt adapter. Isn't there a like a little threaded collar on the end of it? If so just drill, tap and screw it in. Don't go too deep to start with.
The collar is there. But I don't have the adapter. I bought the unit used. I just need to find a new adapter. I'll try to find a diesel performance shop in the area and drop by.
UPDATE:
I spoke with BD tech support. Asked them the same thing. They told me it was personal preferance where the probe goes. Pre-turbo is more accurate, but post turbo is easier, with less risk to the turbo.
Also, I went to a number of places in town looking for that fitting. No luck. No part shop carries it. None of the diesel shops I went to had it either. BD is going to mail me one.
TinJim
26
09-19-2005 11:58 PM
