Pyrometer, boost limits??
We use our 2007 Dodge,automatic transmission and 6.7 l diesel for towing our RV. This weekend we had three gauges installed: pyrometer, turbo boost and transmission temperatures.
What range should I expect to see on these gauges under normal towing? What would the maximum readings, for each, I would not want to exceed?
Jim
Jim
Jim, Welcome to DTR
pyro, i assume it is before the turbo. you will not want to exceed 1400*, not exceed 1300* for more than a few minutes. (if pyro is after the turbo, it will read 300* below these numbers, so 1100, and 1000*)
boost should be around 33-34 stock.
drew03
08-27-2005 11:03 AM
drtwister
04-10-2005 08:06 AM
Hummin Cummins
24
02-24-2003 10:35 AM
