Pyrometer
Pyrometer
http://www.relentlessdiesel.com/stor...a.cgi?p_id=113
1. Will it work on an stock 05?
2. All I need is a holder for it right?
3. Any write ups on how to install? I want to be fimialr with it before i order one.
thanks alot!
thanks alot!
Pyro
Most any pyro will work on any truck, as long as the Temp gauge is correct. I can say you can get a better deal than that, search around, plenty of guys on this site that sell gauges and holders. Most which will answer any question you have when you buy from them (benifit of buying from a company that does business with the forum) Basically you follow the directions, drill the manifold, wire it up like it says, it's really not that hard. I drilled the manifold and used a vacume tube, and magnet to get all the shavings out, then scoped it to check (got all of them out some how) so that's how I did it. So if you do it that way it's easy and my turbo's still singing. for more info, do a search on Pyro, and you'll get more reading than you'll want to do = )
Hummin Cummins
24
02-24-2003 10:35 AM
