Pyro reaction?
Pyro reaction?
Well installed a pyro meter tonight and was wondering how do they typically react? I took the machine for a ride and I was suprised how quickly the temps go up and down according to throttle amount. Sitting at a light the temp is a little above 400 F. When getting into the throttle a little bit I saw temps up to 1000 F and then qickly dropping down to around 600 F while crusing.
I park and let the temp get to 300 F before shutting off. About 3-4 minutes later the temp went back up to approx 330 F.
Is this what I am suppose to See?
Thanks
Thanks
Pre
Located between 3 and 4.
Tried to drop the turbo, and put in above but could not break loose those nuts on the studs.
Thought of a breaker bar or heat but decided not to risk snapping.
Originally posted by nickleinonen
sounds normal to me... get into the throttle hard and watch it get to +1300°f on the 600 engines...
Bookshelf
05-01-2008 04:43 PM
JIMCTD
09-01-2006 09:12 PM
