Pyro Installed. No workie. Pic inculled
Pyro Installed. No workie. Pic inculled. Works now
I put my quad commander on my truck today and drilled and taped the manifold and made sure all the wires were hooked together and it wont read at all!!
Did i drill in a dead spot. It should at least read somthing and mine is staying at 32 degrees
I believe there is a devider (for a lack of a better word) around that area. When you drilled through, did you find an empty chamber? If not, you might have hit the devider. I drilled mine on the round elbow on the # 5 & 6 cylender bank. You might want to uncrew the thermocouple and look to see if there is a void. Also, double check your connections and polarity.
I just drilled mine on the rear of this divider and it reads perfectly.
Even if you did hit the devider,,,I would think surely it would read more than 32*.
You either have a bad gauge, amp box, or probe. Call where ever you bought it and ask them. Did you try tapping the gauge to see if it move's.
Its a quad guage. I checked everything too. I dont know what it is cause it should at least read somthing. Truck is cooling down and im going to look at it again.
When i drilled it was hollow. so i must have went to the side a lil but either way i believe it is working correctly cause my egts are about the same as most people with the same stuff
scootertrash35
12-26-2007 10:50 PM
Checkmate
35
07-15-2007 02:09 PM
Jim Dynomite
05-04-2006 06:25 AM
