puttin the silencer ring back in
Old 09-04-2004 | 10:11 PM
HorseHauler's Avatar
how hard is it to put these things back in?
Old 09-04-2004 | 10:43 PM
Tfeore's Avatar
Takes more work to get the tube off than to get the ring and snap ring back in(It's easy). Why would you want it back in? Just curious...
Old 09-04-2004 | 10:44 PM
Probably a four letter word that starts with "w".
Old 09-04-2004 | 10:54 PM
Tfeore's Avatar
If that truely is the case, the one I've got can't tell a difference.
Old 09-05-2004 | 10:48 AM
no the eight letter word that starts with w... i dont care what she thinks....
Old 09-05-2004 | 11:46 AM
Tfeore's Avatar
I understand your concern but the silencer ring does nothing to effect performance. It can't cause a warranty issue.
It only reduces turbulance into the turbo, silencing the
Tom
Old 09-05-2004 | 11:50 AM
knowing me id find somehow to screw it up and get shavings in their when i take it off... im just a scaredy cat i reckon....
Old 09-05-2004 | 12:10 PM
Tfeore's Avatar
Don't let it scare you, are you tring to get it back in or take it out?
I've had mine in and out 2X. The worst part was losing an 8mm(?) deep well socket. Fell off the extension, hit the block and I have no idea where it ended up.
Old 09-05-2004 | 12:23 PM
i have yet to take it out but trying to figure this all out before i do
Old 09-05-2004 | 12:32 PM
Tfeore's Avatar
Don't let it stress ya, just get after it. You'll look back in a day or two and wonder why you hadn't done it sooner. I used a flat head screwdriver, you can get it under the notch and pull it out. If you want a picture, PM me and I'll send you a pic of the snap ring.
Tom
Old 09-05-2004 | 01:17 PM
Bubba_CTD's Avatar
From: From Texas; Staioned in WA; Transplanted to AZ
Cool
Here's a shot of the ring... just use two small screwdrivers. I tried to use the same one I took the intake tube off and it was jsut too big... that's where I got a couple scrapes from. I used a smaller one that was able to get into the groove better and lifted up enough so I could get a really small screwdriver under it and pried it on out.
Here's a shot when I was taking mine out... you can see the thin dark ring just inside, that's the clip and then the silencer behind it.
Old 09-05-2004 | 11:49 PM
SportTruck's Avatar
Or you could just use a pair of pliers and pull the thing out and throw it in the trash where it belongs. the snap ring will remain on the turbo housing, takes about 4 minutes total. Oh, unless you dont like people asking you why your truck sounds like a jet coming down the road. its your choice. p.s. using pliers will ruin the ring because its about as thick as a pop can-- but who cares about saving the thing.
RonP
02-17-2010 10:30 AM
RRC
05-14-2007 12:45 AM
StrokeThis2500
12-31-2005 06:19 PM
BPD239
11-23-2002 07:14 PM
