PRXB Installed
PRXB Installed
Okay, I've got the brake installed and works like a champ. The Rep. from Pac Brake told me to run it all of the time, to keep it moving. But I forgot to ask him about draining moisture from the tank. Is it necessary to drain the tank once in while?
I often drain mine and only seem to get moister in the winter.
I picked up a dump valve with a cable on it.
I cut the lead off it and the loop hangs just below the bumper.
I just tug it every now and again and let any water out
Yup, I get moisture build up rather quickly in the winter. I like to drain once a month in the cooler weather for sure. I installed a 1/4" NPT petcock valve in the bottom of my tank for fast and easy draining.
j
09-06-2008 02:39 PM
ptgarcia
41
03-06-2007 06:56 PM
ptgarcia
02-07-2007 12:34 PM
Thundercloud
11-22-2006 09:47 PM
