Propane? Who Has It And Should I Get It?
I've Been Resherching Propane Injection Adn Have Decided To Build My Own Kit With The Same Vaporiser\ Regulator That Bullydog Usses, Kit Total With Tank Should Only Cost About $200. Is It Worth It?
I notice on my truck anywhere from 1.5-3 mpgs gained when using the propane, however you have to remember there is the added cost of the propane. I spend about $22.00 on filling my 10lb tank and it lasts me for about 750-900 miles depending on the terrain.
Thanks. Thats what I needed to know. its about what I was figuring, plus you have extra HP to boot, when its needed. I,ve been thinging of going with some propane, and I think I might now. Thanks again.
I've got a Torque-Pro 2000 system from ATS. I like its' adjustability via the Hobbs switch. Mine is set to not even start flowing propane until I have somewhere between 28-30 pounds of boost. It'd work well set lower but then unless I manually turn it on and off instead of just letting it do it's own thing, it goes through way too much propane. It is installed on my 18 wheeler (855 cubic inch - 14 Liter). Have a 60 gallon tank, about 45 gallons usable. By the way, I've had no engine troubles attributable to the propane in over a million miles, probably because I don't run it too rich. Too little air /too much propane equals problems. Mine works real well....
I wouldnt recomend using propane on the common rail 03 and later model trucks never seen one using it with good end result. Propane works awesome on the 12valves and 24valve isb motors but wouldnt recomend on any other ones then those.
Flatbed24v
07-31-2009 11:57 AM
hic316
10-27-2007 12:11 PM
tywebb3
06-24-2006 12:30 AM
PowerDually
06-12-2005 11:51 AM
