Which Programmer? Edge Juice?
Hey, can you guys help me decide which programmer to go with? Here are the basics: 05 CTD, 6SPD, HTB2 turbo, DDP stage 1 Injectors, QZilla Boost Fooler, otherwise basically stock.
I have to drive the truck for work 200 miles a day, so I need reliability. I don't really care about fuel economy, I just want to make the drive a little more fun. Wouldn't mind doing some pulling on the weekends, either. My friends all have Edge Juice, but reading here seems like not a lot of power and not much smoke.(both are important, of course) What programmer should I go with? I like the idea of the Attitude Monitor and being able to keep an eye on things and adjust the power level.
Here's the question(s):
Will the Juice do what I need it to do?
What level can I run it at and drive around all day without bombing the truck?
Is there a better program out there I need to look at?
What is the next mod I should do? (besides a clutch)
Thanks
Thanks
I have one and I like it alot. If you turn the low boost fueling up you will get a fair amount of smoke and you can always get the HOT upgrade for even more power. With your intake/exhaust/turbo upgrades you should be able to support the Juice fine but a clutch is probably a good idea especially if you go HOT Juice.
Thanks
Thanks
The edge does delivers reliable power and it a good box but I have been running the smarty in mine for about two months now and I love it. It makes alot power and I have not had any problems with it yet. If you like smoke it will smoke it will smoke like crazy if you bog it down. And you need to buy a clutch because mine southbend OFE does not like the smarty on level 9 it slip like crazy.
I have the juice on my 06 i like the features like the gauges and the turbo timer and adjustable on the fly, but i like yourself like some too so i am going to have to make a move to get it, but as far as safety and reliable i love it and reccomend it
it does stack but not very popular for some reason...i have no idea why though. I guess most hp junkies that stack the smarty run a TST
I haven't heard of many stacking the edge with smarty either, but I do see a fair amount stacking it with the bullydog. The attitude monitor is very handy and the power gains are good but from my experience I haven't seen an improvement in fuel economy but since you said that's not what you were after here then I would go for it.
MrSuzuki
08-25-2009 07:22 AM
Curbman
04-07-2008 02:24 PM
jdr160
11-12-2007 05:36 PM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
