programers with no fuel pressure increase
I have been doing alot of reading on here, this is my first post. My question is what programers or modules do not increase rail pressure? I want to get one, but would like to go with one that does not increase pressure.
Edge juice/attitude combo is All timing/duration.
Not sure about the smarty. i think its all timing/duration as well.
Bullydog powerpup is timing/duration up to the performance 90hp setting. Crazy larry has pressure.
Luken
Does the triple dog with outlook add any pressure and any settings? The reason I asked is because I am having a problem with my while towing heavy. The last time I used it while towing I had it on performance and she starting bucking really bad. It threw a common rail code that my dealer reset for me but found no other problems. It runs great empty but does not like anything above towing mode when towing heavy.
Thanks
Thanks
Luken
Thanks
Thanks
I have an edge juice w/attitude and my fuel rail pressure sensor tripped the in cab warning light with me mashing hard on it on 3X5. I carried it to get reset and havent mashed it that hard since. I thought the edge did not apply any more fuel pressure. but the diagnostics said high rail pressure. other than that i think it is a great piece. I get 22-24 mpg normal driving w/ 4.10 gears and the six speed
