In the process of modding the cp3 HELP!
Old 11-07-2007 | 07:34 PM
01smoker's Avatar
So, after doing this mod, what can I expect? How does doing this mod perform compared to a pump from Floor-It or II?
Old 11-07-2007 | 07:59 PM
OldSmokey's Avatar
Chris, (the guy that did the write-up) told me that it would let support about one more setting on my tst. I dont think they can really be compaired to a "real" modded pump, but for free Ill take whatever I can get.
Old 11-07-2007 | 08:14 PM
01smoker's Avatar
If I would mod my pump like this and decide later that I wanted to send my pump in to Floor-It to become a stage 2, would this be ok?
Old 11-07-2007 | 09:20 PM
OldSmokey's Avatar
Thats what Im doing!
Old 11-07-2007 | 09:40 PM
HarleyHauler's Avatar
Question from a newbie:
Does the CP3 mod remove the need for a FASS / Walbro pump installation? I am getting fuel pressure readings down to 1 PSI when I stomp on the pedal (thanks to the Smarty) and I was considering installing a pump system. Is the $400-650 lift pump necessary, or just the CP3 mods?
Help!
Old 11-07-2007 | 09:47 PM
drewblood's Avatar
I foun that after the mod I had a surging issue as others have stated and it went away with the use of a edge ez stack with my bddl on crazy larry didnt notice much difference but it was fun to do and its free if you dont mess up I think pressure box works well with it
Old 11-07-2007 | 09:49 PM
BPM's Avatar
BPM
From: Shreveport LA for 10 days at a time, Groveton TX the rest
Harley, yes you need a Glacier or a FASS system put on. If you can't get the fuel from the tank to the CP3 then your not doing any good. 1 psi is pretty low, sounds like one is in your very near future.
Old 11-07-2007 | 09:59 PM
BPM -
1 PSI is only when I really stomp on it, but what's the fun in having a system you can't use to it's fullest, right?!
Any suggestions on FASS vs. Glacier? I have seen folks arguing both ways, Glacier mostly for price and FASS for higher HP needs... Care to give yet one more opinion?!
Old 11-07-2007 | 10:10 PM
BPM's Avatar
BPM
Glacier all the way. It's a walbro pump that can be easily changed out if it goes out for some reason and it's no where near as noisy as a FASS. To many FASS pumps that I have heard were very loud and obnoxious. Cruising at 75 with a stack on a short bed truck and I could still hear the FASS running. That's loud!
I know how fun it is, I just have to wait a while for warranty to run out before I can start changing stuff out!
Old 11-07-2007 | 11:33 PM
gus's 03's Avatar
like dodgezilla said.. 45-60 min
i pop rivit it back together. the actual mods take 10-15 min tops. the rest of the time is getting your hands/tools in there to get it apart/together.
dificulty? id say 2-3 on the shade tree scale... but you have to DEBURR it
it realy isnt much harder than the tone ring mod, gutting the tube, or removing the silencer ring.
Old 11-07-2007 | 11:45 PM
stock600's Avatar
ya but what is this about the surging issue i read? I have an extra fca, im thinking of starting with just doing it only, but i want NO surging it runs very smooth now , just like the thought of increasing flow to the rail.
Old 11-08-2007 | 07:07 AM
madhat's Avatar
Administrator/Jarhead
I tried it last night, the bottom torx bolt twisted my bit and rounded it off...... Dang I was mad! It seemed a lot easier to take the intake horn and the cover for the throttle cable off, I had an extra horn gasket, so no big deal. It gave me a really good view of the pump.
I'm gonna probably have to take the driver side tire off, and the wheel well cover off so I can get a demel in the to notch the bolt so I can get it off, I tried to get some pliers on it (I had already ruined it, why not?), and tried to 'tap' the next size torx in there, but that was a no go, too.
I can get those torx bolts from a good fastner store, right? Or, should I call bosch and get some more...
blwnsmke
23
07-06-2008 07:31 PM
Dwitt0187
12-07-2007 03:26 PM
megacabrule
33
05-10-2007 01:07 PM
Barrett_Fodder
10-07-2004 12:12 PM
gasgas19
06-13-2003 12:15 PM
Quick Reply: In the process of modding the cp3 HELP!
