Problems with DiabloSport Extreme Power Puck and Towing
I picked up a 30 ft Coachman yesterday. It only weighs 6400 lbs so no big deal towing it home, so I THOUGHT. Picked it up in Lansing, MI and started the drive back home with no problems. As soon as we got on the freeway I noticed the truck seems down on power. After a couple miles it starts bucking and surging. I had to floor it to get up to 55 mph. Pulled off the rode and unplugged the Quadzilla Scout from the OBD 2 port just in case. Same problem when we got back on the road. We pulled off at the next exit and I started getting into panic mode thinking about all the things that could be wrong. The next step was to unplug the DiabloSport. Viola! Problem solved. The truck ran like a champ and cruised up to 70 without even a hiccup. The next step will be a Extreme Power Puck going on Craigslist.
The XPP either works or it doesn't. It does not know if you are towing or not. I would venture to say that you may have other issues that were just bought out by the XPP/towing combo. The truck ran perfectly fine without the trailer back there?
Glad you made it home OK. That's always the first thing I check when I have performance issues is the power adders..
As soon as we got on the freeway I noticed the truck seems down on power. After a couple miles it starts bucking and surging. I had to floor it to get up to 55 mph. The next step was to unplug the DiabloSport. Viola! Problem solved. The truck ran like a champ and cruised up to 70 without even a hiccup. The next step will be a Extreme Power Puck going on Craigslist.
I too would say faulty programmer, and would want to know for sure before I just ditched it.
If there is indeed no fault with the XPP then I would surely be lookin hard to determine what made my truck fall flat on it's face.
Just my couple of pennies.
marksblaster
11-04-2012 08:02 PM
teamroper12v
01-09-2009 11:38 PM
burntdodge
24
04-11-2007 11:26 PM
trik396
43
03-03-2007 12:14 PM
fyrguy316
08-09-2006 10:49 PM
