Problem w/ turbo oil return line on 03 w/ Silverbullet
Hey I just got off the phone with II and they couldnt help me very much other then sudguesting I update to a newer style oild line.
Anyways I have an early 03 I guess that uses a hard line out of the turbo and then a small 4" pice of rubber hose that clamps onto a nipple in the block. So now after the turbo is in the hard line and the nipple are off and to the side. I bought a longer pice of hose but its too much at and angle creased the hose so I cut about 2" off the hard line to alleavate the bend but it still bends.
I called many many hose suppliers looking for a silicone hose with a 90' bend in it but no one seems to make them.
II told me that they have heard of this problem along time ago but couldnt remember and thought they used the updated line off an 04 but I dont think my block is tapped where the nipple is.
Has anyone else heard of this or can offer some help for me.
Thanks
Thanks
I dont think bending it will work now because I cut too much off.
I called Cummins but they need an engine serial number to get the part.
Can someone with a 04.5+ please give me there engine serial number off there 04.5+ Its an 8 digit number all numbers.
This is one of thoes lame way the world works..... Once i have the # I can call Cummns
Thanks
Thanks
i cant help you out much i got a 03 here. I am wanting to get a sps62/14 would i have the same trouble as you im guessing? Another question with the turbo im going with do they send a new elbow with it or do i just use my stock one?
sorry for hijacking!
Thanks
Thanks
I can take a quick glance in a sec on my '05(hopefully I can see it with a flashlight)
If not, maybe a braided line, or similar if there are any local performance shops or maybe a NAPA might have one.....
Braided line and a 90* fitting or two should do it....
Steve C.
Rip Rook sells the flexible line Part#428 on his site here:
http://www.sourceautomotive.biz/twin_turbo_parts.htm
ctd4stan
05-18-2009 02:56 PM
973604x4
20
11-29-2006 09:05 AM
973604x4
56
11-01-2006 10:56 PM
