Problem With Boost Fooler
Installed the boost fooler still only surging to 32psi and leveling off at 30psi.(SAME AS STOCK)
Has anybody else had this happen? My led light is coming on green so it should be working right.
If you can un-install the Flashpaq and see what sort of boost readings you get. I am wondering if a particular version of the Flashpaq is doing something weird and not fueling past 30psi or something?
On a bone stock truck the boost fooler should give you 38-39psi very easily. If it does not do that then there may be somthing wrong with the Boost Fooler. I would think if it was acting up then it should set a code though.
WE havea Flashpaq here and we can hit 45psi on the high setting.
Quad
Quad
It works great and a lot of people are using it.
I am curious to get this other one back as we have not had any issues with any of them until this one.
I am curious to see what did not work.
qzilla
Tried the boost fooler on another truck and it wasnt just mine. We seen the same results in his. But anyways called tech support and they said to send it back and they would check it. So it is on the way back today hopefully we will find something and I can get this thing back and get it running...
Thanks for all your help.GREAT customer service!!!
qzilla and del.
all i can say is i should have been ordering parts from qzilla before. i ordered my boost fooler late friday night and paid for regular ground shipment and i got it wed morn. that is great service. i ordered some seat covers for my jeep 3 weeks ago from 4-wheel parts and still haven't seen them. i also wanted to add i talked to one of the guys here from dtr (the phone # is on the page about order discounts) and i forgot to get his name but he was one of the most helpful guys i've talked to.
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
